请问一下FM225录入人脸的时候和验证人脸的时候出现超时
发布于 2024-10-18 17:49:08
环境是 usb ttl ,接的串口, python调试的, 没有设置加密
发送录入人脸正面 和 verify消息, 10次有九次失败, note 消息有大量的没有检测到人脸, 我都调整自己很多个角度了,都不能正常工作
板子用杜邦线接到 usbttl上,没有任何外壳,摄像头的两个贴纸已经撕掉。
以下是我调试发送的返回的数据,帮我看看问题出在哪里?
请输入命令:enroll
packet: ef aa 13 00 23 05 61 64 6d 69 6e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5a
data: ef aa 13 00 23 05 61 64 6d 69 6e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5a
请输入命令:recv: NOTE size: 17
人脸状态:
state: 1 left: 192 top: 272 right: 358 bottom: 474 yaw: 0 pitch: 0 roll: 0
未检测到人脸
recv: NOTE size: 17
人脸状态:
未检测到人脸
recv: NOTE size: 17
人脸状态:
未检测到人脸
recv: NOTE size: 17
人脸状态:
state: 0 left: 130 top: 178 right: 300 bottom: 380 yaw: 11 pitch: 65530 roll: 65534
人脸状态:ok
recv: NOTE size: 17
人脸状态:
state: 0 left: 134 top: 216 right: 286 bottom: 384 yaw: 6 pitch: 65525 roll: 3
人脸状态:ok
recv: NOTE size: 17
人脸状态:
state: 1 left: 134 top: 216 right: 286 bottom: 384 yaw: 0 pitch: 0 roll: 0
未检测到人脸
recv: NOTE size: 17
人脸状态:
未检测到人脸
recv: NOTE size: 17
人脸状态:
未检测到人脸
recv: NOTE size: 17
人脸状态:
未检测到人脸
recv: NOTE size: 17
人脸状态:
未检测到人脸
recv: NOTE size: 17
人脸状态:
未检测到人脸
recv: NOTE size: 17
人脸状态:
未检测到人脸
recv: NOTE size: 17
人脸状态:
state: 0 left: 136 top: 212 right: 276 bottom: 376 yaw: 14 pitch: 65531 roll: 65535
人脸状态:ok
recv: NOTE size: 17
人脸状态:
state: 1 left: 136 top: 212 right: 276 bottom: 376 yaw: 0 pitch: 0 roll: 0
未检测到人脸
recv: NOTE size: 17
人脸状态:
未检测到人脸
recv: NOTE size: 17
人脸状态:
未检测到人脸
recv: NOTE size: 17
人脸状态:
state: 0 left: 180 top: 96 right: 344 bottom: 276 yaw: 11 pitch: 65522 roll: 65535
人脸状态:ok
recv: NOTE size: 17
人脸状态:
state: 0 left: 176 top: 74 right: 350 bottom: 262 yaw: 7 pitch: 65519 roll: 65534
人脸状态:ok
recv: NOTE size: 17
人脸状态:
state: 1 left: 176 top: 74 right: 350 bottom: 262 yaw: 0 pitch: 0 roll: 0
未检测到人脸
recv: NOTE size: 17
人脸状态:
state: 0 left: 174 top: 76 right: 336 bottom: 250 yaw: 7 pitch: 65520 roll: 65534
人脸状态:ok
recv: NOTE size: 17
人脸状态:
state: 1 left: 174 top: 76 right: 336 bottom: 250 yaw: 0 pitch: 0 roll: 0
未检测到人脸
recv: NOTE size: 17
人脸状态:
未检测到人脸
recv: NOTE size: 17
人脸状态:
未检测到人脸
recv: NOTE size: 17
人脸状态:
state: 0 left: 160 top: 70 right: 344 bottom: 284 yaw: 4 pitch: 65525 roll: 1
人脸状态:ok
recv: NOTE size: 17
人脸状态:
state: 1 left: 160 top: 70 right: 344 bottom: 284 yaw: 0 pitch: 0 roll: 0
未检测到人脸
recv: NOTE size: 17
人脸状态:
state: 0 left: 146 top: 186 right: 336 bottom: 406 yaw: 10 pitch: 65526 roll: 0
人脸状态:ok
recv: NOTE size: 17
人脸状态:
state: 1 left: 146 top: 186 right: 336 bottom: 406 yaw: 0 pitch: 0 roll: 0
未检测到人脸
recv: NOTE size: 17
人脸状态:
未检测到人脸
recv: NOTE size: 17
人脸状态:
未检测到人脸
recv: NOTE size: 17
人脸状态:
未检测到人脸
recv: NOTE size: 17
人脸状态:
state: 0 left: 140 top: 60 right: 328 bottom: 282 yaw: 65532 pitch: 65523 roll: 0
人脸状态:ok
recv: NOTE size: 17
人脸状态:
state: 1 left: 140 top: 60 right: 328 bottom: 282 yaw: 0 pitch: 0 roll: 0
未检测到人脸
recv: NOTE size: 17
人脸状态:
state: 0 left: 162 top: 54 right: 372 bottom: 284 yaw: 65532 pitch: 65518 roll: 65533
人脸状态:ok
recv: NOTE size: 17
人脸状态:
state: 1 left: 162 top: 54 right: 372 bottom: 284 yaw: 0 pitch: 0 roll: 0
未检测到人脸
recv: NOTE size: 17
人脸状态:
state: 0 left: 170 top: 62 right: 366 bottom: 282 yaw: 7 pitch: 65523 roll: 5
人脸状态:ok
recv: NOTE size: 17
人脸状态:
state: 1 left: 170 top: 62 right: 366 bottom: 282 yaw: 0 pitch: 0 roll: 0
未检测到人脸
recv: NOTE size: 17
人脸状态:
state: 0 left: 178 top: 54 right: 358 bottom: 248 yaw: 3 pitch: 65516 roll: 65535
人脸状态:ok
recv: NOTE size: 17
人脸状态:
state: 1 left: 178 top: 54 right: 358 bottom: 248 yaw: 0 pitch: 0 roll: 0
未检测到人脸
recv: NOTE size: 17
人脸状态:
未检测到人脸
recv: REPLY size: 2
操作失败
mid: 19 result: 13 MR_FAILED4_TIMEOUT13录入或解锁超时 reply_data:
heatonhuang
heatonhuang 2024-10-19
已经搞定了, 用mid_enroll_single 0x1d 来录入人脸,就可以了, verify 识别速度非常快
chenze_love_code
chenze_love_code 2024-11-09
爱编程,爱硬件!
大佬厉害
