LD6002,接收数据的问题
发布于 2025-01-18 14:25:33
LD6002,串口接收到数据:
W (29776) TF_RX: TF_AcceptChar failed at index: 0, char: 01
W (29776) TF_RX: TF_AcceptChar failed at index: 1, char: 00
W (29776) TF_RX: TF_AcceptChar failed at index: 2, char: 00
W (29776) TF_RX: TF_AcceptChar failed at index: 3, char: 00
W (29786) TF_RX: TF_AcceptChar failed at index: 4, char: 04
W (29796) TF_RX: TF_AcceptChar failed at index: 5, char: FF
W (29796) TF_RX: TF_AcceptChar failed at index: 6, char: FF
W (29806) TF_RX: TF_AcceptChar failed at index: 7, char: FA
W (29806) TF_RX: TF_AcceptChar failed at index: 8, char: 01
W (29816) TF_RX: TF_AcceptChar failed at index: 9, char: 01
W (29826) TF_RX: TF_AcceptChar failed at index: 10, char: 00
W (29826) TF_RX: TF_AcceptChar failed at index: 11, char: 00
Received frame type: 0xFFFF
Received uint32 data: 0
Received float data: 1.576998
Special frame type detected: 0xFFFF
Successfully received TF frame data and parsed the type to obtain version information.
Returning version information as response.
frame type为什么是0XFFFF
这个已经再群聊里回复您了
guojq1123
guojq1123 2025-01-25
在别的提问里看到答案了:
0A13 0A16 是用来绘图的,所以大部分都是这两种数据,像0A14,0A15就是直接上报的呼吸心率结果,但这两种数据判断条件苛刻一些,所以上报慢
谢谢!
